Incoming calls from international numbers
qasimiqbal
Hi there,
I activated a new public mobile sim in Feb ‘23 and haven’t been able to receive calls from my home country, Pakistan. Works fine within Canada but no luck receiving calls from Pakistan
16 REPLIES 16
qasimiqbal
Tried receiving calls from different providers as well but still no luck
@qasimiqbal  again, and important test is to ask  couple friends in Pakistan  with different providers (landline, mobile line, etc) to make the call and test
qasimiqbal
Most of the times, I'm able to get incoming calls just fine. Will try the sim option to see if it makes a difference.
qasimiqbal
Sent a message to CS agent privately. SIMon is pretty useless in my situation.
qasimiqbal
Interestingly, my friend with a public mobile number is able to receive calls from Pakistan
@qasimiqbal   are you getting other incoming calls without problem?
usually if incoming calls, it doesn't matter it was called from Canada or internationally.
But try that, put your sim card in another phone, this will for a sim reprovision and see if it solves your problem.  I suggest you ask not just one but multiple friends from your home country to call you. Better your friends use a different providers there to really test it out.  And if it does not work, please ask those friends what error recording they got.  Was it just busy tone? no tone and hung up? or some error codes
If that still does not work, then it is a really strange issue and worth a look from Public Mobile support to confirm if your account was setup properly
qasimiqbal
This is the first time someone from Pakistan tried calling me. Works fine on other PM numbers that my friends have here in Canada
qasimiqbal
I know and it doesn't make any sense
qasimiqbal
Dialled correctly but there seems to be an issue particularly with my PM number
qasimiqbal
Tried all the suggested options but it doesn't work. Strangely, had my family call another PM number in canada and it works.just fine.
HI @qasimiqbal   call your friend, make sure he dials this way
00 - 1 - 10 Digit Mobile Number
hairbag1
@qasimiqbal
with your active Public Mobile account, you'll be able to receive calls from anywhere on planet Earth. Problem is...the caller might not be able to call your Cdn number from their home.
Maybe he's not dialing correctly too.
Hi @qasimiqbal  there is no difference a call made from Pakistan or here in Canada
first check if you can receive calls from your friends in Canada
If you can, it is a problem on your friend in Parkistan, make sure he dial your number correctly.  Ask him how he made the call, what numbers he put in
dust2dust
Have they ever been able to call you? We should all be able to receive calls from anywhere. But maybe the caller can't call to here.
Yummy
Could somebody else receive these calls from Pakistan?
Do they dial all numbers required for Canada and your number?
Do you have any other number they can try to call (work, friends)?
@qasimiqbal  That’s odd maybe ask support to investigate
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
