Imei
Marcbell22
How can I change me imei #
11 REPLIES 11
Luddite
@Marcbell22  If you are still wondering, then you can relax. If you change phones, the IMEI registered to your account is automatically updated.
@Marcbell22
If your active the SIM with the old IMEI from the old phone, you just put the SIM in your new phone and it should work as longer as the new phone is unlocked.
Are you saying that the wrong IMEI was provided for number porting?  To correct that, you'll have to open a ticket using the chatbot to ask a custoemr support agent for help.  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Jboeringa
That is set by the manufacturer of your phone
Hi @Marcbell22 in case your new phone takes a smaller size sim, check if you can remove the outside to make it smaller.   Most sim cards are 3-in-1 and can remove the outside to make it smaller
If you want to change phones...you just take the sim outta old phone and install it in new phone.
EZPZ.
Marcbell22
Got a different phone
Hi @Marcbell22 you meant SIM #?
IMEI is like a serial  number on your phone..  unique,  cannot be changed
Marcbell22
I do have a different phone but I don’t know how to change it on my account
hairbag1
Only way to change imei is to get a different phone, I suppose.
No can do, otherwise .What makes you ask that question anyhow ?
LurganIeUk
In your phone? You can’t.
