11-16-2022 09:56 AM
I resented my account
i did it again and again
yet I still cannot login
I am not getting email I am not getting verification
No one to talk to this is getting fruswhat is going on
11-16-2022 10:39 AM
I want to thank you all so much awesome all of ya
11-16-2022 10:28 AM
@Mmariapiehl wrote:I did all that again and again but the problem I am not getting the reset email so I do the phone I get it I reset and agin it ask me the same all over again
HI @Mmariapiehl Try to use Private or Incognito browser mode
But this time, login with the passoword you just reset to , the last one you reset to
If that still going nowhere, then please open ticket with CS agent at
https://publicmobile.ca/chatbot.
First type Forgot Login,
11-16-2022 10:22 AM
11-16-2022 10:14 AM
If you reset your password, wait 15-20 min before attempting to log in again.
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
11-16-2022 10:12 AM
@Mmariapiehl With the new My Account, always use Incognito mode to login, it will give you less issue
If you still unable to login, open ticket with PM Support:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
11-16-2022 09:59 AM
Try logging in to your account using another browser in incognito mode. It should work then.
