IMessage not working.
MISMAIL
Hello,
I recently purchased a plan from Public Mobile,, but unfortunately, IMessage does not work.
What is the easiest way to fix this issue?
Thanks
@MISMAIL  In your settings iMessage does it have your number checked off for send and receive ?
can try and reset network settings if that doesn’t work you might want to call Apple support . But to think they will ask you do to just as I have asked . But if you like to talk to PM support
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agent
MISMAIL
Unfortunately, That did not work.
Thanks for the advice
hi @MISMAIL it's is a device problem and you need to do something
go to iMessage settings, remove the phone number
Reboot and then put the number back. for re-register
@MISMAIL  Try this turn off iMessage and turn off face time then go to settings > general scroll to the bottom in blue letters you see  “ shut down “ in my pic
Tap it wait 2-3 mins turn phone back on and turn on iMessage and face time . It will verify and work again
