data
11-13-2024 04:32 PM
Hi Folks, Is the $30 plan different from the 90 day plan? When do I know when my data is all used up?
Plans
02-12-2025 06:36 PM
Thank you all for the responses tto my query. The info supplied is helpful. I appreciate your feedback very much.
11-13-2024 04:55 PM
@kaostream1 wrote:Hi Folks, Is the $30 plan different from the 90 day plan? When do I know when my data is all used up?
You'll know your data is used up when it stops working. Then you must wait until next regular plan renewal occurs.
11-13-2024 04:52 PM
hi @kaostream1 with 90 days plan, you pay 3x the monthly rate ahead (probably with some discount) and PM gives you 3x monthly data up front for you to use in the 90 days. So , you control how you use
but which plan you want to change to 90 days? not all plans have a 90 days choice. Not sure if any 90 days choice for existing subscribers now
11-13-2024 04:38 PM - edited 11-13-2024 04:50 PM
@kaostream1 Only some plans have the 90 day option you will know if it says so in plan description or once you select plan you want you will be given options like this
40GB $45 30 month (30days) or 120GB $120 90 days
with 90 day plan you have to buy the full 90 days upfront so in that pic example $120 with 120GB to use over 90 days and you can keep track of the data in your account or on your phone with some androids but that usually just for monthly at a time . So watching your account website or app is easier way to keep track of data usage on 90 day plans . Also note data usage only gets updated 2x a day so your always seeing the up and until the last 12 hours used
adding @kaostream1 the $30 plan and 90 plan I see right now are the same in the fact they are both CAN/US plans and 4G speed with $30 plan 20GB and the 90 day plan being $102 195GB to use over 90 days
hope this helps
