One account for two phone numbers
WindyTown09
abtest
As mentioned, one account - one email.  However, you might be able to set up an alias for your existing email address.  For Public Mobile, it would look like two separate emails.
If you have trouble to login the 2nd account, ask PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
slusagm
Sorry, only an email address can only be used to create one account for one number
If you need a 2nd one, use another email address to create another account
WindyTown09
WE HAVE ONE TWO PHONE NUMBERS FOR MYSELF AND SPOUSE. ONE EMAIL ACCOUNT. CANNOT LOG INTO ACCOUNT FOR MY SPOUSE.
