Can I use a I phone with my account?
NYJohnny
I need a new phone.I've had this Q6 for 5-6 years.
Getting tough when recharging.
My daughter has a I-phone shes not using.
Can I use that phone?
john
@NYJohnny
No problem if you are using SIM in your LG phone?
I have the iPhone 8, X, 13 Pro Max and 14 Pro Max with no issues popping the SIM from one iPhone or Samsung S9, S22 or S24 to another.
funpig1
@NYJohnny
Do you have a SIM in your Q6 and does your daughter's old iPhone accept SIM cards?
If so, simply take the SIM card out of the q6 and insert it into the iPhone and see if it works. Good luck.
Public818
Yes, Iphone has no problem to use with public mobile
slusagm
what gen is the iPhone?  as long as the iPhone is carrier unlocked, it can be used on PM.
Don't need to worry about VoLTE, nothing wrong to use the phone even without VoLTE
Chalupa_Batman
john
Hello @NYJohnny
There is a VoLTE list of what iPhones can be used with this service. If it's listed here, it can be used.
https://www.publicmobile.ca/en/get-help/articles/volte
