03-21-2025
07:52 PM
03-21-2025
11:50 PM
computergeek541
Hello,
I can't send imessage and facetime with my number. If I go to the imessage or facetime setting my phone number has a loading symbol constantly on it saying "verifying".
Both incoming and receiving phone calls work.
I've tried restarting phone, disabling wifi/data, taking sim out, turning imessage/facetime on and off. nothing works.
Anyone had similar problems and know the fix? HELP.
03-21-2025 07:55 PM
hi @Lina_d
after porting the phone number to a new carrier, sometimes, you need to register iMessage
Go into Settings to disable iMessage, then reboot phone and go back to reenable iMessage to re-register. If it showing "verifying" still, wait, it could take as long as a day or so sometimes
