09-27-2025 02:40 PM
I have an iPhone and since updating to iOS26 my iMessage and FaceTime will not activate. I followed the directions of the forum posts that said “solved” and bought a new eSIM, installed d it and reset network settings. However iMessage and FaceTime still will not activate.
Any advice? How do I talk to PM support and/or get a refund for the new eSIM as it didn’t fix the issue.
10-03-2025 08:15 PM - edited 10-03-2025 08:18 PM
Following a lot more strategies with CS-Agents, I realized today the issue for me was iOS again based on this post:
https://support.apple.com/en-us/125367
Once I removed an old SIM card, iMessage successfully activated. For others who have bought a new eSIM, make sure to delete the old ones that had been connected to your phone number.
09-29-2025 11:09 PM
I still haven’t heard back from a CS Agent since my message on Saturday and still no change in service. Wondering if/how to elevate? Thanks.
09-27-2025 04:35 PM
Unfortunately this didn’t work either.
09-27-2025 04:34 PM
Thanks. Will try this.
09-27-2025 04:25 PM
hi @Mr30
ask PM support agent to refresh your account
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
09-27-2025 03:46 PM
Unfortunately still not working. It shows my phone number under “send” with a spinning/connecting symbol as it had before. Phone number not listed under receive.
09-27-2025 03:08 PM
i would try reregister iMessage this way:
Settings -> Messages, toggle iMessage off, sign out of your Apple ID in the Messages settings, sign back into your Apple ID, then turn iMessage back on.
Restart your iPhone, ensure your phone number is correctly listed under Send & Receive, and confirm your Wi-Fi is on.
09-27-2025 03:06 PM
hi @Mr30
Settings->Phone-> My Number
09-27-2025 03:02 PM
I’ve tried resetting network settings and it didn’t work. I’m not sure where you mean for “remove the phone number”
09-27-2025 02:55 PM
@Mr30 wrote:I have an iPhone and since updating to iOS26 my iMessage and FaceTime will not activate. I followed the directions of the forum posts that said “solved” and bought a new eSIM, installed d it and reset network settings. However iMessage and FaceTime still will not activate.
To "reset" iMessage and FaceTime on an iPhone, turn both services off in the Settings app, then restart your iPhone, and finally turn them back on in their respective Settings menus.
If that fails, then log out of your apple ID on your phone, reboot and once back up, log back into your apple ID.
09-27-2025 02:43 PM
hi @Mr30
Try Reboot and Reset network settings and check if it helps.
if not, try this. go to Settings and remove the phone number there. Wait 15 mins and reboot the phone. Then go back to the Settings menu to enter the phone number back to re-trigger iMessage registration
