05-29-2023 12:10 PM
new site is good but I can't keep my old community id. ok for now. I have access to my account
More pressing question, do I keep my 5$ loyalty and 2$ friend discount if I change to 39$ plan? How long price stay?
05-29-2023 12:24 PM
Yes, I am doing it now but use the schedule change option
05-29-2023 12:19 PM
HI @LostID
When you say Change plan now, I hope you didn't really mean Change plan now. Use Change plan on renewal to have the change start on renewal instead
05-29-2023 12:19 PM - edited 05-29-2023 12:20 PM
@LostID You bet , enjoy the rest of your day
05-29-2023 12:19 PM
Thanks @Handy1
05-29-2023 12:18 PM
Thanks @hTideGnow Yes, submitted
And will change plan now
05-29-2023 12:14 PM - edited 05-29-2023 12:17 PM
@LostID Looks like your one of these folks
bravo the post
yes you get to keep old rewards I did this change too check it out .. I can confirm
Add no expiry on this plan either
05-29-2023 12:12 PM
HI @LostID I can tell you lost your id from your id:)
some people have that problem. you can open ticket with supportand get them to try to fix it
for plan change, you will keep your current discount, you will stay in your old rewards after the plan change.
The price is ongoing, you will be ok after you change plan, not just 12 months or so.
