12-30-2024 05:35 PM
I purchased a new iPhone a few weeks ago from Accurate Technologies, which is an authorized Apple reseller.
They warned me that the phone was locked to Public Mobile, so I switched carriers.
I’m now on the Public Mobile network, and I purchased a new SIM from Public Mobile.
Unfortunately, activation failed. The phone says, “SIM Not Supported” and that I should request that the phone be unlocked by the carrier.
How do I ask Public Mobile to do that?
01-10-2025 06:22 PM
Thanks for the update and I'm glad it's not blacklisted although that could be next for that phone since the US carrier hinted that there's an outstanding device subsidy.
Hopefully Accurate Technologies has agreed to a return and refunded you.
Here's a couple of reputable second hand online resellers that might interest you:
https://recy-cell.ca/en/promotions/?srsltid=AfmBOoolnZwLIqRLGBUQc7c4j-NYV8H9ScpEU-fcvkFKKwtjNL3V6GPp
For reference: iPhone 11-$330 iPhone 14-$645 (both on sale)
For a much larger selection of devices and with up to 50% off during their New Year's sale:
https://secondcell.ca/en/collections/all
For reference: iPhone 7=$138+ iPhone 11=$285+ iPhone 14=$595+
Google Pixel 7's have the highest discounted price (50% off) Starting at $250+ and all Pixel and iPhone 11 on sale come with a bonus screen protector promotion.
01-08-2025 08:59 AM
@HALIMACS wrote:By any chance, is it listed as being blacklisted @LeoDiCroce ?
Check here:
I hope you purchased it from a vendor who will work with you towards exchange/replacement. There are certainly some shady suppliers out there who will gladly sell 'used' devices for good prices only to find out later the devices are either unusable or significant hassles to use.
Best of luck.
Fortunately, the phone is not blacklisted. I'm negotiating with the vendor to replace or refund the phone.
=L=
01-05-2025 09:06 AM
Check here:
Best of luck.
01-05-2025 08:10 AM
I learned recently that the phone is locked to US Sprint/T-mobile. So, this isn't a Public Mobile issue at all.
I'm still glad I posted the question here. This Community and the Public Mobile CSAs pointed me in the right direction—thank you!
=L=
01-05-2025 08:02 AM
@RavingRaven wrote:"Public Mobile 50.0.1" is likely appearing on your iPhone because that's the last provider's sim card to be in the Sim slot. There are other threads here reporting the same info on a locked iPhone.
https://productioncommunity.publicmobile.ca/t5/Get-Support/SIM-Not-Supported/td-p/919634
If you don't have friends or family that use providers other than Telus (and it's flanker brands) then head to your local mall or BestBuy or The Mobile Shop etc....and ask them if you can borrow a Sim card from Rogers, Bell and maybe Freedom if needed to "check compatibility". Once you find which provider's network your iPhone connects to you can narrow down the actual provider although technically you should be able to ask the Network Provider to contact Apple on your behalf to have them unlock your iPhone.
This will be easier if the last sim card that was in your phone is the same as the provider that locked the iPhone originally. Then you can just say it's an old phone from an old account that you are donating to charity... this should hopefully help you avoid any run around other provider's are notorious for when unlocking phones from "former" customers and/or non-customers.
If the iPhone is not locked to the Rogers, Bell or Freedom networks (testing a Sasktel or Eastlink Sim card may be difficult from your location) then consider the possibility that it's locked to a US provider or even another international provider from Mexico or Europe? (Accurate Technologies doesn't have very reliable reviews so they may have off-loaded an iPhone they couldn't figure out who it was locked to either?!!)
Thank you. Yes, the phone is actually locked to "2408 - US Sprint/T-Mobile Locked Policy."*
I called T-mobile. Unfortunately, they did not unlock it and hinted that there may be a balance due on the phone. They suggested taking it back to where I bought it, which I'm doing next week. If that fails, I'll try an Apple Store.
BTW - I like your suggestion about giving it to charity.
*Source: IMEI.info report called "Apple Carrier & Lock Status & FMI Checking." Cost ~$5.00 CAD
01-05-2025 06:16 AM
@computergeek541 wrote:
@RavingRaven wrote:Am I missing something here? If the iPhone is locked to Public Mobile>>Telus it should still work here just not with a Rogers, Bell, Sasktel, Videotron or Eastlink owned provider.
We don't know who the phone is locked to. The store said that it's locked to Publci Mobile, but that appears to be wrong. As to your next likely quetsions: No, Public mobile cannot help unlock a phone that is locked to a different carrier. Only the carrier that the phone is locked to can help.
Nope not even close to what my next question would be but I guess that's what happens when you assume? Thanks for trying though! 👍😀
01-05-2025 06:10 AM
12-31-2024 02:15 PM - edited 12-31-2024 02:18 PM
@LeoDiCroce the phone settings say the carrier is "Public Mobile 50.0.1
Probably moot since the CSA agent is working on it, but where exactly does it say this? Edit, disregard, I just found it in my iPhone under Settings - About - Network/Carrier.
12-31-2024 01:57 PM
Thank you. There is no "Carrier Lock" label per sé under Settings > About.
Here's the screen that tells me the phone is locked...
12-31-2024 01:40 PM
Thank you. Yes, Mario's on it. He's a "CS_Agent" for public mobile.
12-31-2024 07:07 AM
@LeoDiCroce Yes, the phone Carrier is "Public Mobile 50.0.1
It says this next to "carrier lock" in the settings?
12-31-2024 12:24 AM - edited 01-05-2025 07:27 PM
We don't know who the phone is locked to. The store said that it's locked to Public Mobile, but that appears to be wrong. As to your next likely quetsions: No, Public mobile cannot help unlock a phone that is locked to a different carrier. Only the carrier that the phone is locked to can help.
12-30-2024 10:48 PM
12-30-2024 09:22 PM - edited 12-30-2024 09:22 PM
@Chalupa_Batman wrote:Due to the phone itself and the age, perhaps it could actually be locked if sold by Public Mobile back then. The phone is from 2016 and just a year later, Telco's were no longer allowed to sell locked phones. So, with that being said, here is a link to reach out to a CS Agent. Advice them it's locked and may have been locked and sold by Public Mobile before December 1st of 2017 and you require the unlock code. If they are unable to assist, you may need to return the phone.
Public Mobile never sold an Apple devices, but Telus and Koodo locked devices are still in use by some Public Mobile customers to this day. In any event, Public Mobile cannot provide an unlock code for an iPhone 7. There's no such thing as a network unloock code for any iPhone devices. It is true that Public Mobile CSAs can get a Telus/Kooodo locked iPhone 7 unlocked, but they would have to submit a request on the user's behalf to Apple.
12-30-2024 09:18 PM
@HALIMACS wrote:Public Mobile never locked devices.
Public Mobile did actually sell locked devices at one point (even after acquisition by Telus). During a transtion period, Public Mobile was selling Telus-locked phones.
12-30-2024 08:22 PM
Hey @LeoDiCroce
12-30-2024 07:42 PM
@Phil_Adelphus wrote:@HALIMACS They're listed under repairs in your link (Service & Support to be precise).
@LeoDiCroce what model iPhone is it?
Thank you. Yes, you're right; Accurate Technologies is an "Authorized Service Provider." Reference: accurate-tech.com
The phone is an iPhone 7.
12-30-2024 07:39 PM
@HALIMACS wrote:Something's not right there, @LeoDiCroce
Are you 100% certain that business is an Authorized Apple reseller?
Unless I'm missing it (and I hope I'm wrong), I don't see it here: Apple Stores and Apple Authorized Resellers
Thank you. Yes, I thought they were an Authorized Apple reseller. They're actually an "Authorized Service Provider." Reference: http://accurate-tech.com/
12-30-2024 07:34 PM
12-30-2024 07:32 PM
@LeoDiCroce wrote:I purchased a new iPhone a few weeks ago from Accurate Technologies, which is an authorized Apple reseller.
I'm curious, what phone is it? Because as of December of 2017 no phone carrier were allowed to lock phones anymore. The good news is if it is locked, which I still find odd, they can not charge you for unlocking it. Matter of fact, whatever code they give you to unlock it, keep track of it and never lose it.
Thank you. Yes, it's an iPhone 7.
12-30-2024 07:30 PM
@hTideGnow wrote:hi @LeoDiCroce it could still be the phone problem itself.
try the sim card in another phone and see if it works. If it works there but not the iPhone then check back where you got the phone from
if it does not work on another phone too, ask PM support agent to check , you can submit by direct message:
Thank you. Yes, the SIM card works in my old Phone. I'll check back with the vendor as you suggested, after I go through the replies here.
12-30-2024 07:26 PM
@hairbag1 wrote:That's odd because Public Mobile has not been known to "lock" the phone. Go in to the phones setting to see if it actually is locked.
added...You can find out if your iPhone is locked by going to Settings > General > About. If "No SIM restrictions" appears next to Carrier Lock, your iPhone is unlocked.
Thank you. Yes, the phone Carrier is "Public Mobile 50.0.1"
12-30-2024 06:16 PM - edited 12-30-2024 06:33 PM
12-30-2024 05:58 PM - edited 12-30-2024 10:51 PM
(edited out incorrect info)
12-30-2024 05:55 PM
@LeoDiCroce Are you sure it's not locked to PC Mobile?
12-30-2024 05:54 PM
12-30-2024 05:42 PM
12-30-2024 05:40 PM - edited 12-30-2024 05:44 PM
