I switched to the $34 Plan but doesn’t give me 5G
05-29-2024 08:26 PM
Hey , I am just wondering why I am not getting any 5G data or network ?? I’m on the plan .
I am wondering if it’s the SIM card I have . It’s from 2019…
let me know please .
Service
06-03-2024 10:35 PM
I just wanted to provide and update and I have updated my iPhone and now it is showing 5G+
thank you ! All!
05-30-2024 07:00 PM - edited 05-30-2024 07:08 PM
Connect to iTunes for the latest iOS.
Edit: Or follow these instructions from Public Mobile:
To update your device settings, please follow these steps:
- Open Settings on your device
- Tap General
- Tap Software Update
- Complete the update to the latest iOS version available
Need more assistance? Check out this guide on the Apple website on how to update your iPhone.
05-30-2024 10:59 AM
How do I update the carrier profile …
05-30-2024 10:47 AM
HI @Moe41690
make sure you updated the iOS and Carrier Profile is updated
Reboot the phone once more and check
05-30-2024 10:43 AM
I am in the city of Toronto and have an iPhone 14
it only Shows LTE . Not 5G
05-30-2024 10:39 AM
@Moe41690 If your phone is 5G compatible, it may well be that you are located in an area with no 5G signal. Type in your address in the following coverage map and see if you are in a 5G area. If not, drive to a 5G area and retest your phone. Good luck.
05-30-2024 12:36 AM
what phone do you have?? brand and model?? is 5G an option there at the network mode screen??
and make sure you turn off Data Saving and Power Saving, some phones will only use 4G/LTE if those saving modes are enabled
05-29-2024 09:15 PM
You need to have a supported 5G phone with the latest OS update.
I have 8 year old SIM and my phone shows 5G+
05-29-2024 08:55 PM - edited 05-29-2024 08:56 PM
A "5G" plan refers more towards the data speed recieved more than anything else. You can recieve up to 250mbps using the 4G LTE or 5G networks. Connections to the 5G network depend on local cell tower access to the 5G network and a 5G compatible device.
Much of the current 5G network piggybacks on the 4G LTE network until providers begin to deploy the recently auctioned off 5G spectrum licenses.
05-29-2024 08:36 PM
Hey @Moe41690
If you don't see 5G, don't worry about it. Just do a speed test. As long as you're getting 5G speeds, that's all that matters. And don't worry about the SIM card, it will work just fine.
