I purchased add-on PM took my money but did not give dsta
Kennyvu
I am leaving PM and switch to another provider, I need data to use while waiting for the new sim to arrive so I ordered add-on 200mb from PM, they took my money but never give any data, can I sue them???
28 REPLIES 28
Kennyvu
thank you, now I got it
hi @Kennyvu
is your PM service still active? you can receive regular sms from others and just not the porting authorization text?
Kennyvu
Roger has sent request to PM many times but hasn’t received any response from PM, I send tickets to PM customer service, no response too
@Kennyvu  Your public mobile account needs to be active to port out . And leave the PM SIM card in the phone to reply YES to the confirmation text to port out . Once you have successfully ported number out it will automatically close your PM account . But you need rogers to re start the porting request after confirming that PM account is still active
Kennyvu
I have switched my phone to Roger and and wanted to keep my number, Roger did send request to PM many times but couldn’t get approval from PM, why PM kept delaying but didn’t let me go????
Kennyvu
It did not even show on purchase list, my previous balance add-ons still not even used up too
HI @Kennyvu
if they are all used up, it will be gone
did you check the usage history? after you bought the data, it will show
but use Incognito/private/secret mode to check.  And also, the usage history won't posted until after midnight.  So, best to check tomorrow morning
Kennyvu
it didn’t even showed on the list
@Kennyvu
200 Mb is not a lot of data, could be you used up quicker than you thought
Kennyvu
Yes my plan is still under normal operation
Kennyvu
Yes I bought extra data while waiting for Roger sim to deliver, PM just take the money and sold me 200mb data, but it os disappeared next day same as how they withdraw the loyalty bonus data
I see OP is planning to leave, i checked and notice OP was not happy with the lost of loyalty bonus after downgrade.
Look like OP downgraded and now now enough  data to use, buy extra 200Mb.  But I don't see why OP cannot use it.  And other than expressing his frustration, OP never really tells us what was wrong.
golfball
Is your plan active? You can't use add-ons if your plan isn't currently active.
hi @Kennyvu
how they cheat you? did you try to work with PM support and get that data issue resolved?
Kennyvu
Someone cheat me I swear never get back again for sure
HI @Kennyvu I find Telus a very reasonable one.  So, enjoy your Rogers run and see you back in PM next month 🙂
Kennyvu
Customer support doesn’t care about my problems, just try to push around , Telus is even worse than PM
Kennyvu
I may make a clip and upload it to youtube, let many people know how bad this company is and hopefully no one get cheated by this company 🤔
hi @Kennyvu
PM is a great company owned by a big one, Telus.  They won't take your money and not give you the service
did you check if you have data limiter turned on?
did you try to message PM support agent for help?
Kennyvu
I go with roger, 85 for 200gb. Hope big company can treat customers different
EB0
If you bar not satisfied with PM, there are many providers that have similar or cheaper plan than PM. If you are on $15 250mb plan, Koodo and Lucky have $15 500mb 4G plan, Freedom has yearly plan $119 for 15GB, equal 1.25 GB $10 per month
Kennyvu
$5 is small, this can spoil a reputation of big companies
Kennyvu
I bought the add-ons, nothing related to mobile plan
EB0
What is your current plan?
Kennyvu
The customer support just don’t care and just says that I used up all of them, I took all screenshots to prove that no 200 mb add-ons added by PM, it’s the robber company
Rastin
You could try . But you probably just be wasting your money doing it. Have you tried contacting them?
Kennyvu
i am currently with PM, just going to part away with this cheating company
EB0
@Kennyvu
You don’t have a SIM card, means your phone is not working, is it correct? How do you use your add-on data without a phone?
