Accidentally purchased incompatible US Addon
Karan77
Hi,
I currently have a $34 Canada wide subscription, I have an upcoming travel for which I purchased the $30 US Data (3GB)/Text/message Addon.
Unfortunately, after purchasing the addon it says the 3GB US data is not compatible with my base plan.
I think I would be better off switching my subscription instead to US/Canada/Mexico plan.
Is there a way to reverse the recent addon purchase and get a refund?
2 REPLIES 2
hairbag1
@Karan77 wrote:
Hi,
if you bought the 15 Day US Roaming talk/text/3GB data package for your trip to US, it should be just fine once you get to USA. Just make sure to enabled Roaming in settings of your cell.  That data won't work in Canada...only when you cross the border. (you can just ignore the Welcome to USA message with a reminder to buy minuites)
@Karan77 you can ask PM to reverse the transaction and leave the funds on your account as a credit (Available Funds).  You can then schedule a plan change on next renewal using Change on Renewal option
Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
    (if you cannot receive 2FA via SMS, click "Didn't Receive code" or "Resend Code" and choose "Send email" to get 2FA)
