4 weeks ago
Hello,
I ordered this plan back in January, but the SIM card never arrived. After waiting for months, I was finally able to connect with one of your agents, and TODAY I purchased a SIM card myself to start the plan, as I was told I would be reimbursed later.
However, after inserting the SIM card, I received a message saying that my current phone is not compatible with your service. I honestly do not understand this situation. I have been struggling with this issue for months, and now I’m suddenly being told that my device is incompatible, even though there was no clear information or warning about device compatibility when I signed up.
Because of this delay and confusion, I have had to continue using my existing service with Telus the entire time.
I would appreciate a clear explanation and a prompt resolution as soon as possible.
Thank you.
4 weeks ago
You would need to message Public Mobile directly for assistance ti cancel the account. They will advise you on any possibility of a refund.
4 weeks ago
In that case, I can’t switch the plan I’m currently using. Please cancel the plan I applied for, and I would also ask to be reimbursed for the SIM card cost. How should I return the unused SIM card?
4 weeks ago
I am almost certain your phone is not on PM's VoLTE whitelist, but check to confirm
https://www.publicmobile.ca/en/get-help/articles/volte
and even Telus could be dropping the support to your phone, too, so, check as well
https://www.telus.com/en/support/article/how-to-use-volte
there is a chance you need to get another compatible device, once that sold in Canada
4 weeks ago
It’s a gelaxy buddy2
I signed up for two Public Mobile plans. I’m already using one of them, and I’m talking about the other plan.
4 weeks ago
What phone do you have?
Depending on a phone and plan your phone might not be compatible with PM network.
As of Mar '27 some currently working phone will stop working with PM network die to 3G shutdown.
4 weeks ago
tell us what phone is that
everyone is preparing for end of 3G, so it is confusing
check if your phone is compatible here:
