2 hours ago
Hello,
When I'm outside without Wifi and want to connect to the Web, I have difficulties connecting to data. To make them work I need to enable then disable Plane mode (even just enabling it for a second is enough). Then my phone is going to connect to data. Sometimes, it's going to work only for the specific app opened. For example, if I'm on Chrome, I turn on/off Plane mode, the phone connects to the data and I can browse the Web. But if I want to open the Reddit app, I will have to do this process again.
I have a Poco X3, and this issue has been hapening since I started using Public Mobile three years ago.
How do I fix this? Thank you
5m ago
hi @Naoki is the network mode showing 3G only? Also, the top of the screen, the status bar, should show 3G or HPSA (should not show 4G or LTE)
but you will better off with another phone
7m ago
Thank you for the reply.
I already set up my phone to use 3G instead, but not sure if it's actually using that.
2 hours ago - last edited 2 hours ago
@Naoki just to clarify, the phone is not fully incompatible with PM, it is still partially compatible l, that's why it does work sometimes, just not working well
The phone has some compatible 4G bands (b2, 4, 5, 7) but not enough for a stable connection
It does have both 3G bands PM needs, so it will be more stable with 3G, just not as fast, but could still get around 10 - 15 Mbps if you have a 4G speed plan
2 hours ago
Hello @Naoki
Because the phone isn't supported with Public Mobile, the only real option you can try is to go into your network settings and do a reset and then reboot your phone. Sadly with the phone not being supported, you won't get much support with PM help.
2 hours ago
hi @Naoki I think it is a phone problem. I think Poco X3 is not fully compatible with PM Network and hence the 4G or LTE does not connect all the time. It is better to change to a North American model phone
for now, try changing the network mode to 3G and it should connect better
