12-06-2024
05:03 PM
12-06-2024
05:13 PM
computergeek541
Hello , I am new to public mobile . I recently transferred bought a 5G data plan , and my number is finally transferred to the SIM card but I can’t connect the internet . I am wondering if it’s because I need a 5G cellphone to access 5G internet ? The APN setting is correct . I could make a phone call and receive phone call but I can’t access internet for some reason .
12-06-2024 08:04 PM
@ChiaYuan In Settings - Cellular - Cellular Data Options - Voice & Data, what setting has the check mark?
12-06-2024 05:47 PM
I got iPhone 11 for the 5G plan .. I checked my APN is correct
12-06-2024 05:14 PM
hi @ChiaYuan your 4G phone would work perfectly with the 5G plan
what phone do you have?
it could be account setup problem, ask support to check
you can submit by direct message:
12-06-2024 05:13 PM
@ChiaYuan wrote:Hello , I am new to public mobile . I recently transferred bought a 5G data plan , and my number is finally transferred to the SIM card but I can’t connect the internet . I am wondering if it’s because I need a 5G cellphone to access 5G internet ? The APN setting is correct . I could make a phone call and receive phone call but I can’t access internet for some reason .
Using the 5G network isn't required. Public Mobile 5G plans give access to the 5G, LTE, and HSPA networks.
