I'm on autooay but my cell is not working
8secondlx
I have been with public mobile for a bit now. But today my cell won't allow phone calls. Says my plan expired but I'm on autopay
8secondlx
Thanks everyone for the help. So I figured out what happened it was my own fault. Someone scammed my card online a few weeks ago and I got a new one and forgot to update my account here. All good now.
darlicious
@8secondlx
First reboot your phone. Check your payment history. Did autopay take its payment? If so is there a reactivate button showing? Click on it. If not use your card to manually pay your bill. Make sure you clear your browser ancd open one tab only using secret/incognito mode using firefox, chrome or safari.
will13am
@8secondlx , autopay seems to fail on some accounts from time to time.  Are you able to manually perform a top up and renewal.  Give that a try.  If you are unable to restore your account to active status, you should seek moderator team assistance.  The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
