Thursday
URGENT
I last used my cell phone yesterday with outgoing and incoming call. This morning, I cannot dial out and receive any call. SMS is working normal. Checked settings and nothing abnormal; not on "Do Not Disturb", not on "Air Plane" mode. Tried shutting off and restarting the phone. Still would not work.
Tried inserting the Public Mobile Sim Card into another identical phone (Huawei Y9 2019). Still would not work. I concluded that the Public Mobile Sim Card is in fault and needs a free replacement from Public Mobile. Thank you
Thursday
hi @Peter3389
what phone do you have? you see the toggle and you can enable it?
usually the toggle is hidden
Thursday
Same thing happened to my phone, I found the voLET was disabled, when I enabled it, problem solved.
Thursday
@pingkaic1 Is there a chance that you can try the sim in a different brand of phone that is VoLTE approved (see list here) https://www.publicmobile.ca/en/on/get-help/articles/volte
Some else reported earlier that 3G was not working in their area which means that a non-VoLTE phone will not be able to make calls as it can not call over LTE. There are no Huawei phones on the VoLTE list so this would help to eliminate its being a sim problem if your sim works in a VoLTE phone.
Thursday
@pingkaic1 I don’t know if they will but you can ask
here’s how
Thursday
Thursday
How can I ask PM to get a free replacement card?
Thursday - last edited Thursday
@pingkaic1 You can certainly ask PM for reimbursement for new sim , might be quicker to pick one up from Telus /koodo store or order from Amazon . Can take 3 weeks to arrive from PM . Once you have new SIM card in hand log into your account profile page and sim swap the number to keep same phone number and plan
SIM SWAPPING profile tabs
