I have the Us/Canada call, text, roaming data. I am in Montana and cannot recieve or make a call.Hel
06-11-2024 09:26 PM
I have public mobile United States and Canada roaming text talking?
And data
But I cannot receive or call out on my phone. Can someone help me with this please
Thank you
Service
06-11-2024 10:26 PM
Thanks
06-11-2024 10:25 PM
Thanks!!
06-11-2024 10:24 PM
@judy27 wrote:Yes. I have a 3G phone but I am on a 5G plan. It was working in Idaho. Now if I try calling it hangs up in 1 second, and receiving call does the same. This is the first time I tried it in the USA this year. I have this plan with public mobile so I could use the roaming while on vacation.
@judy27 , 5G speed plan is a marketing term for the speed limit placed on the mobile data. It does not mean 5G network connection. All plans can connect to 5G/4G/3G network, provided the hardware is compatible. It sounds like your phone is not VoLTE capable and so phone calls will only work if you are connected to T-Mobile and there is 2G coverage in the area. Try to connect to T-Mobile and make a call.
06-11-2024 10:24 PM
Thankyou!!! I need to get a new phone.
06-11-2024 10:22 PM
Thanks everyone for your info. I believe it is my 3G phone. I will have to invest in a 5G phone when I get back to Canada. My husband is using his 5G phone and all is working well.
06-11-2024 10:08 PM
@judy27 5G plan makes no difference, it's dependent on the phone you have. The US shut their 3G networks down, so in order for phone calls to work you need a 4G or 5G device that is on the VoLTE whitelist:
https://www.publicmobile.ca/en/on/get-help/articles/volte
Alternatively you can try your luck with finding a 2G T-Mobile connection, but that's going to be hit and miss. Data and text should work fine though.
06-11-2024 09:58 PM
@judy27 If your phone can't do VoLTE then make it connect manually to T-Mobile but it depends where their 2G is still available.
06-11-2024 09:37 PM
06-11-2024 09:36 PM
Also manually connect to AT&T or T-Mobile network on your phone.
06-11-2024 09:35 PM
what make / model is your cellphone ? Talk in US using your PM plan requires the phone to be on the PM whitelist of VoLTE enabled phones.
06-11-2024 09:31 PM
@judy27 wrote:I have public mobile United States and Canada roaming text talking?
And data
When you use your phone while you're stil in Canada, do phone calls route through the LTE network? VoLTE is important for voice services while you're in the US due to the lack of 3g/HSPA networks there.
