12-30-2022 04:23 PM
Please Help.
I just signed up my wife for PM and have activated the account. Now I am trying to port her old number from a Bell sim card to PM. The self serve system asks for the IMEI number but I don't know which one to use. The IMEI number from the Public Mobile sim card or the IMEI from the Bell sim. They are both in the phone at the moment and both arer active.
12-01-2024 06:19 PM
Same issue as yours. Using IMEI2 and provided that to Public mobile works
12-31-2022 07:31 PM
OK everyone, my problem is solved. I contacted the porting team and was told that I neede to provide the account number. I gave them the account number and was told that it was not the right account number. . . ? ? ? They gave me yet another number to call to get the correct account number. Did that and they gave me the account number for the number I was trying to port. That number by the way has now been ported at least 3 times and the account number given was from our original cell phone account that we started with years ago. Back to the porting team. I gave him the original account number and I was told that one works! Problem is that 4 hours later, my wifes phone still had the activation number. I tried everything to no avail and finally did a factory reset on the phone. Now, that worked! Everything is now the way it was meant to be. Thanks to everyone for their collective help.
12-31-2022 09:12 AM
call someone else call you and you can hear?
can your wife call others and the other can hear?
try reboot both the phones and see if that resolves the problem
if still not, on both phones, try reseating the sim cards (Power off, take sim card out for a min, then put it back and power on)
If still does not work, try to swap the sim cards between the two phones What it will do is to force reprovision of the sim cards/accounts and that could resolve the problem
12-31-2022 08:25 AM
Okay something wierd is going on. My wife can call me from the ported number but I can't call her. I can text her on the ported number but when she texts me the phone number shows as the number used to activate the phone.
12-30-2022 09:35 PM
you sure incoming calls and text work? that is critical for porting
and you sure you are testing tradition text/sms and not iMessage or RCS?
Try to reboot the phone once more time
If that does not work, another ticket for PM support
12-30-2022 09:33 PM
@Handy1 and @softech I called the number, they saw the phone number that I had activated, they ported that number to the one we wanted but there is still a bit of a problem. My wife can call my number and I can call her number. I can text her but when she texts me, the text appears to be from the number that we originally activated, not the number we ported to
12-30-2022 04:57 PM
@HuronBob Call the number I sent you to see if they see the request
check the credit card to see if PM charged you yet
and put your PM sim in a phone to see if it connects
Let us know what you see and will advise further from there
12-30-2022 04:54 PM
Will do!
12-30-2022 04:53 PM
@HuronBob @Try the number and let us know if there anything else we can try to help with
12-30-2022 04:51 PM
According to SIMon, he says "
12-30-2022 04:39 PM - edited 12-30-2022 04:39 PM
@HuronBob I will also send you a phone number, you can call and talk to live support instead, they will advise if they receive the porting request
Please check your Community inbox (envelope icon on top right) for my message
12-30-2022 04:38 PM
@HuronBob if it is still spinning, do NOT try to close the activate again
I would wait another 5 mins before closing the browser
Then put the PM sim card in an phone to see if it connects
Also, check your Credit card and see if PM took the money yet
Let us know what you see and we can advise further from there
12-30-2022 04:38 PM
OK Great, Ill give these links a try. Thanks for your assistance and I'll let you know how I make out here.
12-30-2022 04:33 PM - edited 12-30-2022 04:33 PM
@HuronBob do not use IMEI as it usually gives error
Login to Bell and get the account number and provide the Bell account number instead. It has LESS error when you provide account number
12-30-2022 04:32 PM
@HuronBob @You might need to submit a ticket with a agent to help further in this case
Getting help from agent , through automation
Or get direct help from a agent right here in the community ( my preferred choice )
12-30-2022 04:30 PM
Unfortunately, I already submitted the IMEI from the Bell carrier and my request seems to be spinning in circles. Can I cancel this and submit the account number instead or just sit back and wait.
12-30-2022 04:25 PM - edited 12-30-2022 04:25 PM
@HuronBob @You can just choose to use her account number aswell , you don’t really need to use the IMEI
