12-01-2024 06:10 PM
12-01-2024 06:20 PM
it does include Hawaii...BUT...when you get home you won't be able to downgrade to a much cheaper plan. If you like your current plan and will be in Hawaii for a couple of weeks, consider getting the 15 Day US Roaming add-on which works just fine in Hawaii. Remember..your cellphone must be on the PM whitelist of volte enabled phopnes to be able to have decent talkability in USA.
12-01-2024 06:15 PM
Hey @BO2222
Yes, Hawaii is include. However, if you are going, I insist you take me with you. 🙂
12-01-2024 06:13 PM
@BO2222 YESS absolutely
