06-09-2023 02:12 PM
06-09-2023 02:33 PM
your Public Mobile account will only allow calls while you're in Canada...unless you pre-paid for a US Roaming add-on for use whilst in USA. You should be able to recieve texts from Canada while in US...you just won't be able to send texts.
06-09-2023 02:32 PM
@CraigB1 if you did purchase a USA Roaming addon, ensure your public mobile account is active. Addons will only work on active accounts.
If proper addon is purchased and your account is active, try restarting your phone, or reset your network settings on your device, this sometimes help get connected to the proper network.
06-09-2023 02:15 PM - edited 06-09-2023 02:15 PM
@CraigB1 You can with a U.S roaming add on
06-09-2023 02:14 PM - edited 06-09-2023 02:14 PM
HI@CraigB1 You can't, unless you bought the US roaming addon ahead
the Long distance addon you might have bought or got from PM as bonus are to be used for calls originated from Canada to overseas. When you are in US, you need to have the US roaming addon
06-09-2023 02:13 PM
Did you buy a talk roaming add-on bundle? Do you have the old $60 roaming plan? Did you dial with the 1 in front?
