I can’t login to my account.
joanna1219
I’ve tried to reset the password a thousand times,
it didn’t work.
Help me.
@CS_Agent
2 REPLIES 2
@joanna1219   you are almost there, you tagged the right group.  Just need to send them a message  🙂
One thing you can do for resetting password.  After the password is reset, do not login immediately.  Wait 5 mins, then use Incognito mode and try logging in
If that does not work, then open ticket with CS Agent:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Timer
@joanna1219
tried use browser from computer,and clear cache and cookies and use one page inPrivate mode,
then  Reset Password
you can't reset then contact support team by CS_Agent  to reset it.
