08-17-2022 09:22 PM
Bought a new phone and it requires a Nano Sim Card, no public mobile kiosk in Prince George and not offered online..
Service
08-18-2022 12:07 AM
As mentioned, in all likelihood you already have a Nano Sim with one or two adapters around it. But, if not, I have successfully cut down several larger SIM cards to Nano size. But I guess if it doesn’t go smoothly you are out of service until you can get a new SIM!
08-17-2022 11:17 PM
@waynecole wrote:Bought a new phone and it requires a Nano Sim Card, no public mobile kiosk in Prince George and not offered online..
SIM cards are offered online. Please see: https://www.publicmobile.ca/en/qc/sim-card
08-17-2022 09:28 PM
The Public Mobile Triple Punch SIM card fits most phones as it’s a Standard, Micro and Nano SIM card all rolled into one; simply remove the adapter on SIM card in the size that fits and insert it into your phone.
or go to Find TELUS Stores Near you or Koodo Stores to buy it SIM card.
08-17-2022 09:25 PM - edited 08-17-2022 09:27 PM
@waynecole Hi do you have one now from your old phone? If it is bigger they break down to nano size if you need a new sim they are available at koodo and telus stores
