08-26-2023
01:29 AM
08-26-2023
12:57 PM
Dunkman
So, I had to replace the defective sim card I was sent upon sign-up, and I can't get a ticket submitted for a $10 refund.
I've deleted the data and cache, I've restarted my browser multiple times, I've used a private window. ERROR: XXX is all I see.
How is it possible that the ticket system is this freaking bad?
08-27-2023 08:06 PM
It almost worked that time, except there's a red banner across the top of the screen that says "There seems to be an error submitting the ticket" when I go to send it.
So... nope. Still nothing.
08-27-2023 07:59 PM
The old sim was mailed when I set up the account last month. Honestly, it was pretty odd -- people complained that they'd have to try to call me multiple times until it would actually ring through, otherwise they'd just get dead air before the answering machine clicked on.
I went from koodoo to PM, so it's not the network or the phone, and a new sim that I bought at a telus store fixed the problem.
08-27-2023 07:56 PM
I know the sim was defective because people calling me would get dead air about half the time before the answering machine picked up, and it wouldn't ring through. A new sim card (from a telus shop) fixed it, the old sim was mailed when I set up my account last month.
Thanks for the suggestions, I'll try number 2 as the chatbot version was what was giving me errors.
08-26-2023 09:35 AM
@kitkate - how do you know the SIM card is defective? What troubleshooting have you tried? Perhaps customer support can fix things in the backend to get it working.
Ways to contact Public Mobile Customer Support (CSA) below:
1-Normally Faster - use this link to: Get Help With Public Mobile Chatbot], and bottom right corner of the page (See the Chat Bubble). It sounds like you tried this method...what if you tried a different device to access Chatbot? When you open Chatbot, type "Contact Us", then go from there.
2-OR, go to your ENVELOPE at the top right of your Community Account which is where your Inbox and Sent messages are. Select the orange/peach color box with the pencil inside it to start a new message. Type CS_Agent in the SEND TO box. This will create a private message to Public Mobile Customer Support.
08-26-2023 08:19 AM
The ticket system hasn't been working since the change and transition to EverSafe ID in May.
Use one of the links provided from the user's below to message a Customer Support Agent directly on The Community for Support.
08-26-2023 03:23 AM
Where did you purchase the SIM because it is rare that a SIM is defective?
You can only activate the SIM on the PM app and access your account on the website and app once the SIM is activated.
08-26-2023 01:40 AM
Or if that is still broken then use this:
08-26-2023 01:32 AM - edited 08-26-2023 01:35 AM
Hi @kitkate ,
See if this link works for you whilst signed in to your Community account: Submit a Ticket . Type "Ticket" in SIMon (chatbot) to get a ticket started and submitted. Hope this helps.
