11-15-2024 05:19 PM
11-22-2024 07:11 AM
The phone is android and data doesn't get used if Mobile Data is toggled off. I want him to rely on the wifi when at home. The only explanation would be if the tab was switched to ON
11-22-2024 07:03 AM
Thanks, I did that already and it still showed 69mb/250mb after the text warning. That's why I went to PM Community. I just checked and those missing mb finally got updated.
11-21-2024 08:04 PM
when you said app shows used 69Mb, you were referring to Public Mobile app? try drag screen down to force update , it will show you more updated usage
and check the data usage on your phone
11-21-2024 08:02 PM
@wuntunmein 250mb not a lot of data and could get used up easily updating apps or using MMS picture messages / videos also when at home on wifi if he has wifi assist on it can use cell data when you think your only using wifi so turn that off if he has iPhone
11-21-2024 07:59 PM
I have the most basic plan for my son. 250mb data and 2 days ago the PM app showed he used 69mb. Today, he reached his limit. The app shows no big usage since 2 days ago. What is going on?
11-15-2024 05:31 PM
@RonMorey I think as phones get better with better quality recording and then when streaming videos off you tube with higher quality video it’s gonna eat up more data especially if it’s been recorded in 4K and streamed in 4K only way to combat it would be to turn your resolution down to 1080P or 720P help data consumption
11-15-2024 05:26 PM - edited 11-15-2024 05:27 PM
hi @RonMorey my experience with PM over the years is that the data tracking was generally accurate
but since you have problems with it, ask PM support to check.
And instead of the AI, easiest way is to open ticket with PM support is to use direct message using this link
