09-28-2023 10:08 AM
I accidentally paid twice. How do I get $$ back? Also, does “Talk Booster 500” mean adding minutes? Public mobile needs to name things better.
09-28-2023 10:24 AM
@Anne68 "Also, does “Talk Booster 500” mean adding minutes?"
Yes, it adds 500 Canada wide minutes (only applicable to the $15 plan since all others are unlimited Canada wide minutes)
09-28-2023 10:11 AM
@Anne68 pm is pre paid typically no refunds . You will need to explain to support what’s happened and hopefully they can compensate you for it . Best of luck
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-28-2023 10:10 AM
To contact a CS Agent directly, use the link below.
