12-27-2024 06:30 PM
12-27-2024 07:23 PM
For now I already have my old subscription with new numbers which I have changed yesterday and one I got new today because before buying I talked to an agent they said if you get new there is possibility you can get you number back if it’s not assigned to somebody
12-27-2024 07:17 PM
You got me 100%
12-27-2024 06:57 PM
@Muhammad61- If I am understanding correctly, you did a number change yesterday, and now you want to get your previous number back. Is that the case? If so, I think you probably are out of luck.
12-27-2024 06:52 PM - edited 12-27-2024 06:57 PM
your Public Mobile account MUST be active to be able to port it to your new network. If your PM acct is suspended, you can pay to get it going again, then port away if you want to.
added...
Suspended means you can get it back after you renew current plan (pay for plan).
Deactivated means your PM acct is closed down permanently.. You'd need a new sim to start a new account...with a new number.
12-27-2024 06:49 PM
It was deactivated due to change number to new so for now a I want to keep both old and new
12-27-2024 06:44 PM - edited 12-27-2024 06:46 PM
@Muhammad61 - What do you mean by cancelled yesterday? Was your payment due yesterday, and you simply didn't pay on time? If that's the case, you can simply pay the amount required, and reactivate your plan on the same number.
12-27-2024 06:40 PM
it’s canceled yesterday not yet assigned someone
12-27-2024 06:36 PM
once deactivated due to being suspended for 90 days or more...that number will go back to wherever it originally came from. (If you ported in to PM from somewhere else...that's where that number is now.) Try dialing it to see if it's been re-assigned.
12-27-2024 06:32 PM
@Muhammad61- If your number was deactivated because it was not used/paid for 90 days, then there is nothing that can be done.
