02-22-2023 05:03 PM
Hi
I am going to Europe and want to know how to stop rooming for there are too many scam text message and incoming call that I want to prevent rooming charges due to this kind of scamming.
Thank you
Service
02-22-2023 08:58 PM
You will NOT have ANY service outside of this continent so no spam or lewd calls while you are in Europe holding phone with PM SIM in your hand.
02-22-2023 08:24 PM
HI @pmpgsusana Again no worry, PM does not offer roaming in Europe, So, won't have any prepaid charge at all
if you need data, use the local data sim card. Europe has many choices and those cards work in most European countries. Cheap and lots of data. Great deals everywhere
02-22-2023 08:18 PM
02-22-2023 08:18 PM
@BKNS27 no , you are absolutely correct. PM sim won't even functionin in Europe. So OP wont not have got the scam text or phone calls that would cause him roaming charge at all
My reply above about the text from Pm asking to buy roaming was meant if he ever in US before and got those text (or maybe he was with another provider before and got that)
02-22-2023 08:00 PM
I am surprised that they will get a text if they are in Europe.
02-22-2023 05:29 PM
@pmpgsusana PM is prepaid service and only provide roaming service in US.
If you didnt but roaming addon, you won't be charged for using it
Yes, you might receive text from PM trying to ask you to buy roaming. Best way to avoid that is to turn on Airplane mode them you can enable Wifi back if you need Wifi. So, Airplane mode on and Wifi on
02-22-2023 05:05 PM
@pmpgsusana public mobile won’t work in Europe , so you shouldn’t need to worry about that … and just get a local SIM card while your away leave PM SIM card at home so you don’t lose it
