Can I recall the Points redemption?
Billslam
Hi, Can I recall the Points redemption? I have place the wrong products.
HI @Billslam   Point redemption could be final  😞
But try to ask CS agnet and see if they can do you a favour to reverse it (and what you picked and what you want instead?)
Please open ticket with CS agent  at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@Billslam  You need to ask support for this if it’s possible
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
cellphoneuser1
Usually no but ask a CSA if they are willing. Go here for help.  https://www.publicmobile.ca/en/on/get-help
@Billslam  Points redemption could be completed almost instantly.
But I think you can still open ticket with PM support and ask  (please let us know the result)
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
