02-21-2023 01:58 PM - last edited on 02-21-2023 02:01 PM by computergeek541
02-21-2023 02:46 PM
no need to argue with people like this. Pretty sure that post will be gone before end of day today
02-21-2023 02:29 PM
Hi @Vsong1966 what did you do ? did you try to reboot your phone? Both voice and data do not work?
It could be just problem with setup of the sim card on the system. Please open ticket with PM CS agent:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
02-21-2023 02:02 PM
@Vsong1966 Also did you try to port a number to PM on activation and miss the text ? If so there a number to call Telus port team I’ll send you it private message
02-21-2023 01:59 PM
@Vsong1966 Did u reboot the phone
02-21-2023 01:59 PM
have you rebooted phone? try asking simon
