08-04-2023 05:35 PM - last edited on 08-04-2023 08:20 PM by computergeek541
Im in the process of my number transfer but got stuck. Someone from Telus reached out to help but I don’t have a way to call them back! According to PM there is no call number and no service agent at Telus knows how to get a hold of PM.
08-04-2023 06:09 PM
hi @Sarahcs
I know you have 3 private messages already. When you call porting team, provide them account number of the old carrier. You might have given IMEI earlier and that usually cause problems.
Reply here and let us know your port is completed
08-04-2023 05:44 PM
@Sarahcs , 3 of Us have sent you a private message with the phone number for help with porting your # into PM. Hope it helps 🙂
08-04-2023 05:40 PM
no worry, There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
08-04-2023 05:39 PM
@Sarahcs If you’re trying to port in to PM there’s a number for live support hat can help . Will send private message. If your trying port out and need support for account number heres that link
private message To CS_Agents click
VVVVV Link below VVVVV
08-04-2023 05:36 PM - edited 08-04-2023 05:38 PM
@Sarahcs wrote:Im in the process of my number transfer but got stuck. Someone from Telus reached out to help but I don’t have a way to call them back! According to PM there is no call number and no service agent at Telus knows how to get a hold of PM.
@Sarahcs ,
You can send a private message to a CS_Agent: -> https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Customer Support Agents are available from:
A CS_Agent will respond back in your Community mailbox at the top right of this page (envelope icon to the left of your community avatar).
@Sarahcs , I will send you a private message for the number for help with porting into Public Mobile.
