04-29-2024
01:28 PM
04-29-2024
05:45 PM
computergeek541
Why is it so difficult for me to get hold of an agent today. I want to know if the subscription choices have changed recently. I used to get the $15.00 with 250mb but now it doesn't seem to have the data with it.
04-29-2024 03:55 PM
I think the new $15 is better than the old one if you just need talk & text because it is unlimited talk & text rather than 100 minutes plus 250mb of data.
You can connect to free wifi everywhere or your home wifi for data.
04-29-2024 01:55 PM
HI @Aye
the new $15 plan does not have data. But if you have the $15 plan already, that won't affect you. You will keep your old $15 plan with 250Mb data. Only the new subscribers don't have a choice to get your old $15 plan with data, but you are fine
