3 weeks ago
3 weeks ago
if the problem is that you cannot download the app to subscribe using the older phone, and if you are using physical sim card, you can ask a friend to help. Ask a friend to download the app and go through the activation process for you. Once activated, you can put your physical sim card in your phone and start using the service. Also, after activation, you can access all your account details using a browser at https://myaccount.publicmobile.ca/ So, you don't need the app anymore after activation
