02-16-2022 12:44 PM
Did not really get how the new way rewards works: the old way when the new payment comes, it’s automatically reduced your payment for how much my rewards are.
but today my payment only showed $5 less that I refered a friend from last December, but didn’t show any of my auto pay rewards and my refer friends rewards.
Any ideas?
02-16-2022 12:49 PM - edited 02-16-2022 12:51 PM
The $5 credit for 6 months was the More is Merrier promo.
Just login to Self Serve account and click on My Rewards>Access Rewards and will have a breakdown of your rewards.
Everything will be credited on your next bill payment.
BTW, DON’T switch over to the Points system if your plan is $40 or less…you will get a better discounts on your plan if you stick to the Rewards system.
02-16-2022 12:46 PM - edited 02-16-2022 12:49 PM
Hi @Lehaha
Login Page Rewards and check it,
maybe your friend non-payment, will be suspended
and when them make payment then reactivated.and will automatically you see the rewards in account.
Edit: 1 point earned is valued at 1 dollar when redeemed - it’s that simple. Rewards (publicmobile.ca)
02-16-2022 12:46 PM - edited 03-09-2022 05:23 PM
@Lehaha with the new one you, you have to cumulate to 15 points and you have to go into My Rewards system and "buy" the $15 bill credit using your 15 points. Even it reaches 15, if you don't "buy" it will stay there and continue the cumulation
The $5/month for 6 months from the Christmas Special friend referral is different. That one is an actual $5/month deposit to your account
02-16-2022 12:51 PM
Instead of actual $ amount you receive points which you convert to $. Plus you can participate in lottery.
Brief introduction is here https://www.publicmobile.ca/en/bc/rewards
02-16-2022 12:52 PM
HI @Lehaha
Are you on the new Rewards ? There is NO MORE Autopay $2 discount but just 5% from your bill, and show up in points Logon to My Rewards (https://www.publicmobile.ca/myrewards) , you should see those points there.
You regular friends referrals will show up as 1 point per referral per month.
But as @softech said, the Christmas special referral would still be a $5 on your My Account.
02-16-2022 12:53 PM
So, if I didn’t “buy” the $15 rewards this month, it’s not expired, right?
02-16-2022 12:55 PM
@Lehaha wrote:So, if I didn’t “buy” the $15 rewards this month, it’s not expired, right?
@Lehaha No, it won't expire, it will just keep growing.
Login to https://www.publicmobile.ca/en/bc/myrewards and you should see your current points and the point cummulation history
02-16-2022 01:13 PM
How do I know if I already switched to the points way or not? I just remembered I registered it
02-16-2022 01:15 PM
@Lehaha wrote:How do I know if I already switched to the points way or not? I just remembered I registered it
@Lehaha Login to My Reward site. If you see everything shows has dollar value ($), you are still on the old system
However,if you see everything showing as Point values and if you see a side tab "Catalogue" and you see items like my screenshot above, you are on the new system
