How do I transfer my pm account to lucky mobile
Jas2317
Where do I go on what website of from where do I do all of this I searched in the pm app but idk
2 REPLIES 2
eddieO
@Jas2317 if you are transferring out of PM your new carrier will need to initiate the number porting request. Be sure to keep you old PM SIM card in your phone as you will be receiving a text message confirming you want to port out your number. You will have 90 minutest to respond Yes
@Jas2317  Just make sure your PM account is active . And start the porting request with new provider . Leaving your PM sim in the phone to reply YES to the confirmation text to port number out . After your successfullly transfer PM number out it will automatically close your PM account for you
