07-08-2024 10:00 AM
Hi!
I'm a returning PM user. Using the app to transfer my number over but Coextro (my current provider) isn't in the drop down menu for porting my number to PM. What should I do? I'm afraid of losing a number I've had for 12 plus years.
07-08-2024 11:01 AM - edited 07-08-2024 11:03 AM
if your number can ported, then no need to worry
Try to choose Rogers and check if it works. If you got an email saying something wrong, there is a team to call and can help
07-08-2024 10:53 AM
@Fublicckobile Check your community inbox in a couple of minutes and I'll private message you a number to call. If they can't help at this stage then open a ticket with customer service at the chat icon bottom right of this page. If the chatbot doesn't work then send a private message to support using this link
07-08-2024 10:29 AM
Yup. That's what I'm leaning towards, but didn't want to screw it up/lose my number.
07-08-2024 10:27 AM
@Fublicckobile Apparently it runs on Rogers, might that work?
07-08-2024 10:22 AM
Thanks for the quick reply! It says it is eligible for moving when I typed it in.
07-08-2024 10:02 AM
first, check if your number can be ported into PM using this link (it is a Koodo link but Koodo and PM are both owned by Telus and using Telus system, the result will apply here as well)
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
