How do I know if my phone will work on the Public Mobile network?
01-05-2015 04:24 PM - edited 01-04-2022 12:31 PM
Public Mobile works on following frequencies:
- For 3G use (UMTS/HSPA): 850MHz/1900MHz bands
- For 4G/LTE use: 1700MHz/2100MHz bands
- For 4G/LTE use: 700 MHz band
Which means most of the 3G,4G HSPA/ LTE phones that are compatible with these frequencies will work on Public Mobile. If your phone is locked to specific carrier, you’ll have to get it unlocked.
Phones compatible with Telus, Koodo, Bell, Virgin will work on Public Mobile network. All 3G, 4G phones from Rogers, Fido and ChatR are compatible and will work on the Public Mobile network.
To verify if you phone will work on Public Mobile network click here
Joining Public
12-02-2024 10:10 AM
Thanks for the super fast response here @hTideGnow !! The phone is a Samsung Galaxy A15 5G 128GB Android Cell Phone (Unlocked CAD Version), more specifically SM-A156WZKAXAC.
Thank-you so much!
12-02-2024 10:03 AM
hi @Magonus
this is a very old post, that's why the link is dead. May I know what phone you have? we can check for you
12-02-2024 10:01 AM
To verify if you phone will work on Public Mobile network click here results in Error 404 – Gone, but not forever We’re sorry, but this page is currently unavailable. Please check back again soon. Link is dead.
05-20-2021 04:18 PM - edited 05-20-2021 04:19 PM
Public Mobile uses the following frequency bands:
4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
HSPA: 850 MHz, 1900 MHz (UMTS).
4G = B2 (1900), B4/B66 (2100 or 1700), B5 (850), B7 (2600), B12/B17 (700), B13 (700), B29 (700-Suppl. DL), B30 (2300)
3G = B2(1900) B5 (850)
Your spec looks ok to me. Which specific phone (brand and model) you have in mind?
05-20-2021 04:15 PM
@CuterNSweett : Looks like it'll be fine.
05-20-2021 04:07 PM
Hello,
Here are the specs of the phone I am thinking. Can you please let me know everything will be okay? Cheerio
2G GSMGSM850, GSM900, DCS1800, PCS1900
3G UMTS B1(2100), B2(1900), B4(AWS), B5(850), B8(900)
4G TDD LTE B38(2600), B40(2300), B41(2500)
4G FDD LTEB1(2100), B2(1900), B3(1800), B4(AWS), B5(850), B7(2600), B8(900), B12(700), B13(700), B17(700), B20(800), B28(700), B66(AWS-3)
Thank you s!
02-16-2020 11:15 AM
Thanks a lot
12-08-2019 10:59 PM
Hey!
If you are concerned about it or have hesitations, take your phone to a place that can set it up for you (like London Drugs, they are amazing!) and answer all your questions in person. They are usually quite knowledgeable and willing to help.
This is what I did and it really helped me chose PM. Plus, I had a really good experience.
12-07-2019 08:44 PM
@waternlava yes. There's no issues with those specs.
12-07-2019 08:31 PM
Will a motorola moto g7 power work?
2G bands | GSM 850 / 900 / 1800 / 1900 |
3G bands | HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100 |
4G bands | LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 12(700), 13(700), 14(700), 17(700), 20(800), 25(1900), 26(850), 29(700), 30(2300), 38(2600), 39(1900), 40(2300), 41(2500), 41(2500), 66(1700/2100), 71(600) |
11-01-2019 11:08 PM - edited 11-01-2019 11:10 PM
It's a new one and not listed there...
About frequencies I'm a bit confused
Thanks for your answers!:) I'll take something else
11-01-2019 10:48 PM - edited 11-01-2019 10:56 PM
@mnsh wrote:GSM: 850/900/1800/1900
WCDMA: 850/900/2100
FDD-LTE 1/3/5/7/8/20/28
TD-LTE 38/40/41
Will it work?
I would stay away from this phone.
With only B5 on 3G/WCDMA even the call function can be compromised (you'd want B2 (1900) as well as B5 (850).
On 4G only B7 is overlapping with the Telus/Public Mobile frequencies. (B4 is in widespread use for data in Canada).
The 2G/GSM frequencies would only work on the Rogers network, Bell/Telus network does not support that technology.
11-01-2019 10:42 PM - edited 11-01-2019 10:43 PM
WCDMA: 850/900/2100
TD-LTE 38/40/41
Will it work?
It might, but if you don't already have it, I would advise against purcahsing this device. As this phone lacks WCDMA 1900MHz (Band 2), this phone is not very good for use in Canada.
11-01-2019 10:35 PM
Or look at top of page and click "Get Started"...Check your phones compatabilty to see if your phone will work here
11-01-2019 10:32 PM
WCDMA: 850/900/2100
TD-LTE 38/40/41
Will it work?
07-22-2019 09:14 PM
06-26-2019 12:09 AM
This link you provided was great!
Thanks.
06-26-2019 12:07 AM - edited 06-26-2019 12:08 AM
@koo wrote:That website doesn't have my phone model# listed.
The phone was not sold in Canada and the US.
What is the required spec used in public mobile?
The phone spec:
- 3G UMTSB1(2100), B2(1900), B4(AWS), B5(850), B8(900)
- 4G FDD LTEB1 (2100MHz), B2 (1900MHz), B3 (1800MHz), B4 (AWS), B5 (850MHz), B7 (2600MHz), B8 (900MHz), B17 (700MHz), B28 (700MHz)
Looks to me like it should work.
06-26-2019 12:02 AM
The phone spec:
06-25-2019 04:41 PM - edited 06-25-2019 04:41 PM
@koo wrote:My phone is samsung a9 pro unlock phone. Can I use public mobile without problems?
Please see the specs below:
- Infra2G GSM, 3G WCDMA, 4G LTE FDD, 4G LTE TDD
- 2G GSMGSM850, GSM900, DCS1800, PCS1900
No problem! You can check by yourself at willmyphonework.net... just to be sure. If the phone was bought in Canada or US...
06-25-2019 04:38 PM
06-08-2019 03:13 PM
06-08-2019 03:09 PM
@DallasL wrote:@Anonymous That what I am seeing. I jsut didn't know if there was a difernt modem for sprint or somthing. It seems like the unlocked "Sprint versions" of the phone are often cheeper than unlocked from other cariors.
You need to look for the protocol and the frequency together. I was just looking at one source. Check with LG themselves to corroborate.
06-08-2019 03:09 PM
If your device is locked to any other provider than Koodo or Telus, you will have to take the phone to the last carrier service it was on and have them unlock it.
06-08-2019 03:07 PM - edited 06-08-2019 03:08 PM
06-08-2019 03:05 PM
@dabr It looks like they might be pulling directly from "Will My Phone Work" as the LG selection is the same. It's great for older phones, but nothing newer than the G5.
06-08-2019 02:58 PM
@DallasL wrote:Will an LG V40 "Sprint Unlocked" work on Public Mobile? All the info I can find seems to indicate it should, but I wasnt sure if diferent cariers might have custum modums? Will my Phone Work doesnt list any LG phone newer than the G5.
Information on gsmarena suggests it should be fine.
06-08-2019 02:56 PM
Did you try this: https://productioncommunity.publicmobile.ca/t5/Announcements/Introducing-the-new-and-improved-phone-...
06-08-2019 02:53 PM
03-30-2019 11:07 PM
Thanks for the helpful answers everyone!
