02-02-2022
07:07 PM
02-02-2022
11:29 PM
Dunkman
Hi I would like to start earning community rewards but I do not know how to connect this account to my public mobile account. Is using the same email enough or is there something else I need to do to recieve these rewards?
02-02-2022 07:29 PM
@D_M : ....and case. I seem to remember someone a while ago struggling to get it linked and they figured out it was case. But that's a while ago now. So look in the box with your name and email address and alternate number. Match that email address - case and all - to the email address here.
02-02-2022 07:14 PM
Alright thanks!
02-02-2022 07:14 PM
Just matching email addresses isn't quite enough. Make sure you have verified your community email address as well.
02-02-2022 07:12 PM
Use same email when registering for account and Community.
02-02-2022 07:10 PM
Thank you!
02-02-2022 07:08 PM - edited 02-02-2022 07:10 PM
@D_M just make sure the email address used in your Community account the same as the email address used on My Account. when it is time to give out Comunity Reward, PM will match the email addresses o both systems.
