02-02-2022
03:39 PM
02-02-2022
11:36 PM
Dunkman
i need help with having a port request sent again. I can not receive calls and I’ve been trying to get help for the last two days and I’m no further ahead.
If it is not possible to get any help this service is useless to us and I would like a refund.
02-02-2022 09:17 PM
@Juliana1 wrote:i need help with having a port request sent again. I can not receive calls and I’ve been trying to get help for the last two days and I’m no further ahead.
@Juliana1 - sorry to hear of your issues with trying to port over a number.
Cell phone numbers take 2-3 hours to complete. Did you leave the old provider's SIM card in your phone and receive a text to approve the port?
Landlines/voip numbers take longer, 3+ day to complete.
Incoming calls are usually the last to port over.
Try one or more of the below troubleshooting:
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings on your device
If issues porting or transferring a number to Public Mobile, and it has been over the allotted time it usually takes to complete, submit a ticket here for help: https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=1ml7MK2dvkmM37lFcEM...
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
02-02-2022 05:42 PM
The only way to have the porting process restarted again, you need to contact a CS_Agent by private messaging them by clicking on the envelope icon on the top of this page.
It sounds like you didn’t leave your old SIM in your phone for the SMS text from your old carrier confirming that you are porting over to PM.
Unfortunately, PM is a pre-paid cell service so refund is not available.
02-02-2022 04:24 PM
Hi @Juliana1
do you receive and respond to the SMS asking to confirm if you would like to Transfer your number, your reply should be: YES
if you stuck with Transferring, or not complete processing
get in touch with Customer Support Agent (publicmobile.ca)
02-02-2022 03:46 PM
you can in fact call a porting support team and talk to live person and ask to re-trigger the text for porting. I will message you the phone number. Check the Community inbox, envelope icon on the top right
02-02-2022 03:40 PM
Contact customer service agents.
Open a ticket via:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
