03-13-2025
01:07 PM
03-13-2025
04:11 PM
computergeek541
Not really a question, just a positive comment and an observation. Recently returned from Mexico. Using my phone in Mexico worked great. No problems at all. Made one ooops, and called a friend in the USA, which i believe is not free. and after dialing at times had to pick either the roaming country or home country to make the call. One box started with a 52 (roaming country) the other started with 1 (home country). This didn't always happen. Probably whatever service provider I was using in Mexico...I believe it is between two. I knew I had to activate roaming for this to work. But everyday, all day i got an annoying notification that my roaming was on and may occur roaming charges. Tried to turn this off but couldn't figure out how. This sure is better than paying $17 a day to use my phone in another country. So when my subscription renews in a few days, i will give a big kudos to Public
03-13-2025 01:16 PM
All calls are Unlimited as per plan so you can call anybody in those 3 countries from any country of these 3 countries.
03-13-2025 01:14 PM
No extra charge for calling US. so, no worries
Always call with a 1 in front or +1 in front of the 10 digits
03-13-2025 01:12 PM
Good to know. Thanks.
If your call from Mexico went through to US, it should be included, right? No way to charge you separately. Maybe others can confirm.
