5 hours ago
Hello,
This might have been asked before but I haven't been able to find an official answer for it. I'd like to take advantage of a promotion but on my renewal date since I still have 15 days with my current subscription. If I change it now but to apply on my next renewal date, will PM honour the current pricing even if it's different at the time it's applied?
Thanks
4 hours ago
hi @joseph_1986 use Change on Renewal to schedule the plan change in renewal
don't use Change Now. Change Now will start the plan today and the current cycle will be wasted, no partial refund
4 hours ago - last edited 4 hours ago
@joseph_1986 wrote:Thank you for your reply. So if I change it now, to apply on next renewal date, does it also lock the price?
Hello @joseph_1986
Simple answer, YES! They will honor the price plan. Then within a few days you'll see it saying... Upcoming Changes on the plan page.
4 hours ago
4 hours ago
@joseph_1986, yes, if you select the plan with "Change on renewal" you will get the price after your current plan ends regardless if the plan changes or is no longer offered. Word of advice, take a screenshot of the plan in case for some reason there are any issues, which has happened before
4 hours ago
hi @joseph_1986 if you can find the plan on your My Account, Change Subscription page, them you cam school a plan change using Change on Renewal to lock in to the plan today
so, do it before the plan is gone
