05-15-2024 12:41 PM
So, right now there’s a subscription for $34 CAN/US but it ends May 20. If my subscription renewal is May 27, but I opt in for the change now-will I get the $34 rate even though it ends May 20? I suppose I am asking if opting in before May 20, validates the promotion? Or because of my renewal date of May 27, does it invalidate it?
Plans
05-15-2024 01:17 PM
Thanks! I think this was a classic case of overthinking it…just needed the reassurance
05-15-2024 12:48 PM
@KristineK Yes as long as you set the change before May 20 it will be honoured, so you are safe to select "Change on Renewal" and not "Change Now". Change Now would switch and charge you immediately, so you would lose what's left of your current plan.
05-15-2024 12:47 PM
@KristineK wrote:So, right now there’s a subscription for $34 CAN/US but it ends May 20. If my subscription renewal is May 27, but I opt in for the change now-will I get the $34 rate even though it ends May 20? I suppose I am asking if opting in before May 20, validates the promotion? Or because of my renewal date of May 27, does it invalidate it?
You will get the plan as long as the scheduled request was made while the plan is still being offered.
05-15-2024 12:46 PM
You can just login to PM app and go to Subscription tab>Manage Subscription>Change Subscription.
Make sure you click on Change Subscription on your Next Renewal date now to take advantage of the promo.
