04-25-2023 04:27 PM
All of my calls are cutting off after a few minutes. At first I thought it related to my speaker on my iphone but it cuts off even if I am not using.
Does not cut calls I make over fb?
Any ideas are welcome.
Thank you
04-25-2023 10:07 PM
@sdthenc You can use this test call service to call and record a message for playback, as well as start a real-time echo test. When doing this you can compare when using the phone speaker/mic, speakerphone, external wired/or wireless bluetooth headphones etc to rule out a hardware issue.
You can also test calling with LTE mode (in case your phone is using the new VoLTE feature) or when forcing your phone to 3G-only mode to see if that makes any difference as well..
Anyhow, here are the two canadian numbers, from "The Test Call" http://thetestcall.blogspot.com/
Toronto: +1 416 342 9562
Victoria:+1 250 412 5922
04-25-2023 04:58 PM
Did the problem start after your last renewal? It could be a provisioning issue if it isn't related to the VoLTE glitchiness. You can try to reprovision on your end. Use this troubleshooting list and make a test call after each step....
04-25-2023 04:57 PM
as suggested by @Luddite , it worths to try either manually doable VoLTE, if the option. is there, or change the Preferred network type or network mode to 3G and it could resolve the voice cutting out issue
04-25-2023 04:43 PM
@sdthenc this happened to more than one number?? just happened today or for couple days?
First to try with a reboot
Also make sure you have the latest Carrier profile
Try your phone at a different location as it could be just a local network issue
if that cant resolve your problem, try to click Reset all networks, but please not that will delete your saved Wifi too and you need to join them again
And you have updated to the latest iOS?
04-25-2023 04:30 PM
Hi @sdthenc
which iPhone you have? Check if you can enable VoLTE
and does it happen everywhere? Maybe just. a problem where you are and better if you try in another area
04-25-2023 04:29 PM - edited 04-25-2023 04:30 PM
Are you on a minute Limited plan?
Are these incoming or outgoing calls, or a combination?
If you have unlimited calling, contact the customer support agents and ask them to reprovision your account - it may solve the issue.
