05-14-2019 08:19 PM - edited 01-05-2022 07:30 AM
My next renewal date is supposed to be June 12 but under autopay it says June 1st also when I call*611 it says June 1st anyone have an idea what’s going on similar thing happened last month what a system ha ha
05-20-2019 10:36 PM
@CellGirl wrote:
Adding on to others' suggestions, each month I make a manual payment of the "amount due", afew days in advance of my due date, even though auto-pay is enabled. I've never had a problem with loss of service, which you will surely run into at some point, if you just depend on auto-pay to kick in..
I agree with @CellGirl and others with the suggestion to add sufficient $$$ to Available Funds before renewal. I've done this for several cycles now and have avoided the glitches that can sometimes happen.
Good luck whatever you choose to do.
05-20-2019 10:22 PM
05-14-2019 10:49 PM
@Luddite, when this AutoPay mismatch date issue first appeared, I read that Moderators had informed the Oracles to ignore the AutoPay date at the bottom on the first page. Has anything changed since then?
@RossN, please refrain from contacting Moderators for non-urgent needs. I think they are already busy and the waiting time for Moderators is long enough.
If you want a 100% renewal, make sure you have sufficient amount in Available Funds to cover the next bill period.
05-14-2019 10:31 PM - edited 05-14-2019 10:32 PM
@RossN wrote:My next renewal date is supposed to be June 12 but under autopay it says June 1st also when I call*611 it says June 1st anyone have an idea what’s going on similar thing happened last month what a system ha ha
@RossN You can avoid the headache by asking the moderator team to sync the dates. Others have also reported that removing Auto-pay and the enabling it again will sync the dates up again but my choice would be to have the moderator do it.
05-14-2019 09:07 PM
@RossN wrote:I guess I will find out June 1st if they charge my cc early pm is giving me a headache 🤕
05-14-2019 09:03 PM
05-14-2019 08:55 PM
As long as you have service, use autopay, and are charged correctly I suggest you ignore all messages in your account. If you want to be extra careful, add a one time payment equal to your plan cost, less rewards, a week before renewal. But leave autopay ON for the reward.
Are you feeling really pessimistic? Then get a fongo.com account as backup for calling/sms, or peruse this post: https://productioncommunity.publicmobile.ca/t5/Getting-Started/100-SERVICE/m-p/183753#M33693
PM is an adventure lately; and not in a good way. ![]()
05-14-2019 08:39 PM
Don't bother with those informations....it happened with my account and when I went on incognito mode all informations were correct...![]()
