12-09-2023 01:18 PM
Help please. I can not access my account to change the payment method.
The web page just gives choices to buy plans.
My credit card has changed (was lost), and I need to change it for the next payment.
The phone is a flip phone.
Thank you for any help!
Debby
12-28-2023 10:41 PM
SOLVED...had to use a different card, VISA wouldn't work.
12-19-2023 04:33 PM
@Luddite , I don’t know! I found the post confusing even though I’ve read it several times! 😞 We did try to help though based on the information we were provided! Hopefully the CS_Agent was able to get it fixed.
12-19-2023 02:01 PM
@LitlLdy @hairbag1 Suspect @DebbyDave22 never setup their Eversafe account, and, as we all know, it's quite difficult with their type of phone.
12-09-2023 05:04 PM
@DebbyDave22 wrote:I tried, but it only gives options to download the app, or buy another subscription.
"The Future is Friendly" - Telus
Welcome to forced app, forced 2FA, forced telemetry. Anti-consumer. Sorry, your "dumb" flip phone isn't compatible with Telus's plans to monetize you and your data.
12-09-2023 03:22 PM
Please delete this. I am not getting answers, and am in talks with an agent. Thank you.
12-09-2023 02:52 PM
@DebbyDave22 wrote:After logging in, where do you click to get to the option? That's the problem. I'm in & it doesn't give any options.
To manage your payment method follow these steps:
Or use direct link: Update Payment Card
12-09-2023 02:22 PM
12-09-2023 02:17 PM
@DebbyDave22 wrote:Thanks, but that wouldn't even be possible. I just can't find the spot to enter anything.
Use a laptop and look at ....https://www.muskbird.com/mobile+recharge/public-mobile/
Public Mobile Recharge Instructions
To Top Up Public Mobile you can choose from below top up instructions:
12-09-2023 02:13 PM
12-09-2023 02:10 PM - edited 12-09-2023 02:11 PM
if your renewal is getting close, remember you can also pay by getting payment vouchers at Shell Gas, London Drugs or many other retail suppliers of them. Once you get the vouchers, just dial 611 to add'em to your account and you're set for successful renewal. Then you can deal with credit card issue at your leisure. There's aslo on-line vouchers from Muskbird.com, Recharge.com and Ding.com...they usually have a small user fee though. (muskbird is the least expensive of the bunch and widely recommended)
ed...sp
12-09-2023 02:09 PM
12-09-2023 01:59 PM - edited 12-09-2023 02:00 PM
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
If you are trying to use your flip phone to access PM site, maybe your phone is not exactly 'compatible' with modern internet?
12-09-2023 01:52 PM
Thank you!
12-09-2023 01:52 PM
I can not get it to open online. It just gives ads.
12-09-2023 01:45 PM
I would suggest to use computer to change credit card info.
12-09-2023 01:22 PM
@DebbyDave22 Here’s a link to customer support
send a private message To CS_Agents
