Transfer of service
Kim_Siemens
I transferred my existing number to a public subscription and activated an eSIM but I still do not have cell service after 9 hours. What can I do to fix this?
2 REPLIES 2
@Kim_Siemens
can your eSIM connects to PM network? if it cannot connect, it is an eSIM setup issue, not porting, not yet
Let's try to get your eSIM setup first
Did you get to the eSIM installation step?   Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
TheSterlinger
Seems as there porting process failed. I will send you the number to reinitiate the process. Check your messages click your avatar and click inbox.
