06-18-2024
01:14 PM
06-18-2024
03:28 PM
computergeek541
HELP! I am trying to message CS_Agent, but i am getting the following error, continuously:
"Correct the highlighted errors and try again. Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and send the message when you are satisfied."
How can I get this message across?
Hi CS_Agent,
I am a new subscriber to Public Mobile. I started my subscription on Saturday, but as of today the app continues to be stuck on the "Step 6 of 6: Activate" stage, with the error message "SUBSCRIPTION NOT ACTIVATED." I have tried to delete and reinstall the app, restart my phone, etc., but it has so far not worked, even after waiting over the weekend to see if there were any potential delays given the system outage for upgrades.
I have paid for the service, but have not received the eSim activation email, just the "Thank you for your purchase!" email.
Can you please assist me in getting my service activated and phone ported please?
Thanks!
08-13-2024 07:24 AM
06-18-2024 01:27 PM
thanks guys this worked!
06-18-2024 01:18 PM
When that error pops up you can try sending the message again without any changes, if that doesn't work try copying it into a notepad and then pasting it and see if it works then.
06-18-2024 01:16 PM
hi @jtowers91
yes, your activation likely stuck somewhere. You will need support agent to help. Please submit ticket by direct message here:
