10-01-2024
10:50 AM
10-01-2024
03:40 PM
computergeek541
Hey all,
I see this question has been asked before but I see conflicting info in the answers. I’m going to the states tomorrow and I currently have the plan that says “Unlimited Canada-US wide minutes and messaging plus unlimited international text and picture messaging.”
I originally got this thinking I could call America from Canada without paying for long distance there, but apparently that’s not the case.
Will I be covered during my trip to call and text my American friends there without having to get a roaming add on? Also, what about data? Do I have to buy a data roaming package?
thank you and apologies. This is one of the worst worded packages. Haha!
10-01-2024 11:40 AM
@Littleleah78 wrote:. Says 50GB within Canada and US. If my phone is covered I’ll look into turning on roaming. Thank you.
yes, that is the line you want and that confirmed you have a Canada-US plan!!1
10-01-2024 11:37 AM
you can enable Data Roaming and just leave it on. PM is a prepaid service...you won't be billed later on for any overages or extra anything. Mine has been enabled since 2017.
10-01-2024 11:28 AM
I have an iPhone 14.
looks like days is included. I can see plan details on a desktop but not my phone. Says 50GB within Canada and US. If my phone is covered I’ll look into turning on roaming. Thank you.
10-01-2024 11:23 AM - edited 10-01-2024 11:28 AM
@Littleleah78 wrote:Yes, I have seen your replies elsewhere but I’m not a snowbird. So I don’t know what a “true plan” means. Also, nowhere in my plan does it say data extends to America. So I’m leery there. Thanks for the help tho.
he just meant that many snowbirds subscribe to that plan as they can call most any Cdn / US number while in USA. If you log in to your account / Subscription...can you see if your plan is a Canada / US plan ? If so, you should have no problem calling / texting /using data while in US. Let us know what make / model the cellphone is and we can let you know for sure.
added...does it look something like this ? If so, you can use your cellphone in US, just like you would in Canada.
10-01-2024 11:22 AM
iPhone 14 is VoLTE enabled on PM. So, an easy answer for you is if you have the Canada US plan, you will have no issue with voice or text or data
10-01-2024 11:20 AM
No clue what a PM VOLTE is. I have an iPhone 14. I have read everything in my account and the plan and it’s super limited info. What I posted in my question is what I can see. It’s limited and frustrating.
10-01-2024 11:20 AM
if you want, post a screenshot of your plan details and maybe we can confirm if it is a Canada US plan
10-01-2024 11:18 AM
10-01-2024 11:04 AM
what make / model cellphone are you using while in US ?
10-01-2024 11:03 AM
from the wordings of what you posted, look like you have a Canada-US plan, so it should work. But if you check My Account again, go to Subscripton and check if it talks about Canada and US data
if you have the correct Cnaada-US plan, make sure you turn on Roaming mobile data when you are there, and connect to T-Mobile or AT&T or Verizon
and what phone you have? voice will work if you have a phone on PM's VoLTE whitelist
10-01-2024 10:57 AM - edited 10-01-2024 11:02 AM
If you have the Canada/USA plan it should work for calling and texting to your friends in the USA from Canada.
It should also work in both countries for data without extra roaming charges.
Make sure you have Roaming and VoLTE enabled in your phone settings. You may have to manually connect to AT&T or T-Mobile network.
10-01-2024 10:55 AM - edited 10-01-2024 10:56 AM
@Littleleah78 Yes that’s a true snow bird plan It’s has roaming built into it no need to lay for anything extra . you can call to and from each country using talk text and data . When in the U.S. make sure you have data roaming turned on in phone settings . And set phone to 4G/LTE not 5G and make sure your connected to T mobile AT&T or Verizon
